Ga door naar hoofdinhoud
Dell OptiPlex GX260 Case Replacement
  1. Dell OptiPlex GX260 Case Replacement, Case: stap 1, afbeelding 1 van 2 Dell OptiPlex GX260 Case Replacement, Case: stap 1, afbeelding 2 van 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To close the case, simply press it closed until you hear the tabs click into place.
18 andere personen hebben deze handleiding voltooid.
Kevin Schapansky
1.478 Reputatie
9 handleidingen geschreven
Cal Poly, Team 4-48, Amido Fall 2010 Lid van Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Leden
27 handleidingen geschreven
1Gids Commentaar
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
technojunkie_1999 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 76
Altijd: 20,142
