Ga door naar hoofdinhoud
Dell OptiPlex FX170 CMOS Battery Replacement
Wat je nodig hebt
  1. Dell OptiPlex FX170 CMOS Battery Replacement, Case: stap 1, afbeelding 1 van 1
    • With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
    • Pull the base stand straight up from the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell OptiPlex FX170 CMOS Battery Replacement: stap 2, afbeelding 1 van 2 Dell OptiPlex FX170 CMOS Battery Replacement: stap 2, afbeelding 2 van 2
    • Unscrew and remove the eight 4mm Phillips #0 screws (four on top, four on bottom) from the top and bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell OptiPlex FX170 CMOS Battery Replacement: stap 3, afbeelding 1 van 3 Dell OptiPlex FX170 CMOS Battery Replacement: stap 3, afbeelding 2 van 3 Dell OptiPlex FX170 CMOS Battery Replacement: stap 3, afbeelding 3 van 3
    • Run the flat side of the spudger along the entire line of the case starting from the back where the power plug and a small screw are located.
    • Use care to not apply excessive force that could damage retaining clips while running the spudger along the case.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell OptiPlex FX170 CMOS Battery Replacement: stap 4, afbeelding 1 van 2 Dell OptiPlex FX170 CMOS Battery Replacement: stap 4, afbeelding 2 van 2
    • Once the clips have been released, gently disengage the cover from the rest of case by pulling in opposite directions.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell OptiPlex FX170 CMOS Battery Replacement, Memory Board: stap 5, afbeelding 1 van 1
    • Using the spudger, gently push on the underside of the memory board to loosen it. Gently grasp each side and pull up to release the memory board.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell OptiPlex FX170 CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 1 van 1
    • To remove the battery, pull up on the connector that is plugged into the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 1,375
