Ga door naar hoofdinhoud
Dell Latitude E7270 Solid State Drive Replacement
Wat je nodig hebt
  1. Dell Latitude E7270 Solid State Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Solid State Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
    are you sure they are M2.5x8mm? they look more like M2x8mm
    Charles Beauchemin - Antwoord
    The screws should be captive, so no need to remove them completely.
    engiNURD - Antwoord
  3. Dell Latitude E7270 Solid State Drive Replacement: stap 3, afbeelding 1 van 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Solid State Drive Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
    FYI - You only remove the 2 outer screws as the hole in the middle is used by a screw on the base cover.
    CJ NI - Antwoord
    If you have a 3-cell, 42Whr battery (Type 7CJRC; DPN: 021X15), you only remove one screw, near the plug of the battery.
    engiNURD - Antwoord
  5. Dell Latitude E7270 Solid State Drive Replacement: stap 5, afbeelding 1 van 2 Dell Latitude E7270 Solid State Drive Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Solid State Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Solid State Drive Replacement, Solid State Drive: stap 7, afbeelding 1 van 1
    • Locate the SSD stick on the bottom right of the device.
    • In the absence of an SSD, a RAM stick was used as a substitute for visual and educational purposes only. The SSD in your device will resemble a RAM stick but may differ in color.
  8. Dell Latitude E7270 Solid State Drive Replacement: stap 8, afbeelding 1 van 1
    • Slide the SSD of its socket.
Conclusie
1Gids Commentaar
Thumbs down for showing a memory module and not a SSD.
Christopher Gehringer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 78
Altijd: 4,482
