Ga door naar hoofdinhoud
Dell Latitude E6510 RAM Replacement
Wat je nodig hebt
  1. Dell Latitude E6510 RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Use a J1 screwdriver to remove the 8mm screw on the bottom cover.
  2. Dell Latitude E6510 RAM Replacement: stap 2, afbeelding 1 van 1
    • Unclasp and pull the memory card up.
    • Be careful when unclasping and releasing the memory card. Clasps are fragile.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kolin Doyle
500 Reputatie
4 handleidingen geschreven
Baylor, Team S8-G4, Johnson Fall 2017 Lid van Baylor, Team S8-G4, Johnson Fall 2017
BU-JOHNSON-F17S8G4
1 Lid
Één opmerking
There should be four steps to this, step two should be removing the 4 hard drive screws,
step three should be removing the bottom cover, including that it slides off, as many bottom covers snap in.
I almost damaged the bottom cover trying to pry it up.
Brian Barlow - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 1,989
