Inleiding
The purpose of this guide is to inform the reader on how to properly remove the RAM from their Dell Latitude 3310.
Wat je nodig hebt
Remove seven 8.0 mm screws using a Phillips #1 screwdriver.
Remove three 5.0 mm screws using a Phillips #1 screwdriver.
Lift the plastic cover up to expose the memory chipset.
Carefully pull the clips away from the chip to disengage them.
