Ga door naar hoofdinhoud
Dell Inspiron N5030 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron N5030 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron N5030 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Inspiron N5030 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron N5030 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Inspiron N5030 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Inspiron N5030 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Flip over the laptop and open it so that the screen faces you.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Inspiron N5030 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Inspiron N5030 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Inspiron N5030 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  8. Dell Inspiron N5030 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Dell Inspiron N5030 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the top keyboard panel.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Gunnar Salazar
128 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-59, Amido Spring 2014 Lid van Cal Poly, Team 10-59, Amido Spring 2014
CPSU-AMIDO-S14S10G59
4 Leden
5 handleidingen geschreven
2Gids Commentaar
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - Antwoord Deel
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 38
Altijd: 3,270
