Ga door naar hoofdinhoud
Dell Inspiron 9300 Trackpad Replacement
Wat je nodig hebt
    1. Dell Inspiron 9300 Trackpad Replacement, Trackpad: stap 1, afbeelding 1 van 1
      • Remove the battery in to order avoid damaging internal components.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 9300 Trackpad Replacement: stap 2, afbeelding 1 van 1
      • Remove the twelve 6mm Phillips screws from the bottom of the case.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Inspiron 9300 Trackpad Replacement: stap 3, afbeelding 1 van 1
      • Gently pry away the silver bezel above the keyboard and below the display using a spudger.
      • There is a notch on the right-hand side of the bezel for easiest removal.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Inspiron 9300 Trackpad Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 9300 Trackpad Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 9300 Trackpad Replacement: stap 4, afbeelding 3 van 3
      • Remove the two 5mm Phillips screws retaining the keyboard.
      • Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
      • Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward, away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell Inspiron 9300 Trackpad Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 9300 Trackpad Replacement: stap 5, afbeelding 2 van 2
      • Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
      • Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
      • Support the display as you loosen the hinges, to avoid the screen falling and breaking.
      Vraag FixBot
      Voeg opmerking toe
    6. Dell Inspiron 9300 Trackpad Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 9300 Trackpad Replacement: stap 6, afbeelding 2 van 2
      • Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
      • Gently pry the CMOS battery out of its retaining clip using a spudger.
      Vraag FixBot
      Voeg opmerking toe
    7. Dell Inspiron 9300 Trackpad Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 9300 Trackpad Replacement: stap 7, afbeelding 2 van 2
      • Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
      • Remove the trackpad ribbon cable from the motherboard using a spudger.
      Vraag FixBot
      Voeg opmerking toe
    8. Dell Inspiron 9300 Trackpad Replacement: stap 8, afbeelding 1 van 1
      • Pull up and away on the upper case to remove.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Steven Faulkner
214 Reputatie
2 handleidingen geschreven
USF Tampa, Team 16-6, Eyestone Fall 2016 Lid van USF Tampa, Team 16-6, Eyestone Fall 2016
USFT-EYESTONE-F16S16G6
5 Leden
77 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 507
