Inleiding
The 700m has room for two sticks of RAM, but one is hidden under the keyboard. Use this guide to replace both.
Wat je nodig hebt
Unplug the power cable.
Flip the 700m over and remove the battery.
Slide the battery release switch toward the center of the 700m, and then pull the battery free from the back.
Remove the two Phillips screws securing the RAM cover.
Remove the RAM cover and set it aside.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Lift the RAM module to an angle of about 30 degrees and slide it out.
Remove the two Phillips screws securing the inner RAM cover.
Tilt the right side of the RAM cover up at an angle and pull it free.
4 andere personen hebben deze handleiding voltooid.
