Ga door naar hoofdinhoud
Dell Inspiron 3520 Optical Drive Replacement
Wat je nodig hebt
    1. Dell Inspiron 3520 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 3520 Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 2
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 3520 Optical Drive Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 3520 Optical Drive Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 3520 Optical Drive Replacement: stap 2, afbeelding 3 van 3
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: stap 3, afbeelding 1 van 2 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: stap 3, afbeelding 2 van 2
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 3520 Optical Drive Replacement: stap 4, afbeelding 1 van 1
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Inspiron 3520 Optical Drive Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 3520 Optical Drive Replacement: stap 5, afbeelding 2 van 2
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: stap 6, afbeelding 1 van 2 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: stap 6, afbeelding 2 van 2
      • Locate and remove the 4mm Phillips #00 mounting screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 3520 Optical Drive Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 3520 Optical Drive Replacement: stap 7, afbeelding 2 van 2
      • Push the optical drive from the inside a little bit to dislodge it.
      • Grab the drive with your hand from the outside and slide it free.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Ian
1.638 Reputatie
5 handleidingen geschreven
USF Tampa, Team 16-2, Watkins Winter 2015 Lid van USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Leden
30 handleidingen geschreven
1Gids Commentaar
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 3,132
