Ga door naar hoofdinhoud
Dell Inspiron 1545 Keyboard Replacement
Wat je nodig hebt
    1. Dell Inspiron 1545 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
      • Turn the laptop over to its back.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 1545 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Slide the release latch while simultaneously pulling backwards on the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Inspiron 1545 Keyboard Replacement: stap 3, afbeelding 1 van 1
      • Slide the battery out of the battery bay.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Inspiron 1545 Keyboard Replacement, Base Cover: stap 4, afbeelding 1 van 1
      • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
      • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 1545 Keyboard Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 1545 Keyboard Replacement: stap 5, afbeelding 2 van 2
      • Carefully lift the base cover vertically away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Inspiron 1545 Keyboard Replacement, Center Control Cover: stap 6, afbeelding 1 van 1
      • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 1545 Keyboard Replacement: stap 7, afbeelding 1 van 1
      • Flip the laptop over to the front and open the display as far as possible.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Inspiron 1545 Keyboard Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron 1545 Keyboard Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron 1545 Keyboard Replacement: stap 8, afbeelding 3 van 3
      • The Center Control Cover is VERY fragile, be careful when using prying tools.
      • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
      • Carefully lift the Center Control Cover away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Inspiron 1545 Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 1
      • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 1545 Keyboard Replacement: stap 10, afbeelding 1 van 1
      • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
      • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Inspiron 1545 Keyboard Replacement: stap 11, afbeelding 1 van 1
      • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Inspiron 1545 Keyboard Replacement: stap 12, afbeelding 1 van 1
      • Lift the keyboard up and away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
Nathan Lemay
3.160 Reputatie
15 handleidingen geschreven
Cal Poly, Team 9-14, Regan Spring 2014 Lid van Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Leden
3Gids Commentaar
Step 4 and 5 are not needed.
James Thrun - Antwoord Deel
Steps 4 and 5 are unnecessary for removing the keyboard. Other than that, well done.
lee - Antwoord Deel
The connector latch is broken. What should I do?
Mjeed - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 63
Altijd: 8,014
