Ga door naar hoofdinhoud
Dell Inspiron 1526 Memory Module Replacement
Wat je nodig hebt
    1. Dell Inspiron 1526 Memory Module Replacement, Remove the Cover: stap 1, afbeelding 1 van 2 Dell Inspiron 1526 Memory Module Replacement, Remove the Cover: stap 1, afbeelding 2 van 2
      • Follow the procedures in Before You Begin.
      • Turn the computer upside-down, loosen the eight captive screws on the cover and remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Inspiron 1526 Memory Module Replacement, Popping up the Memory Module: stap 2, afbeelding 1 van 2 Dell Inspiron 1526 Memory Module Replacement, Popping up the Memory Module: stap 2, afbeelding 2 van 2
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Inspiron 1526 Memory Module Replacement, Remove the Module: stap 3, afbeelding 1 van 1
      • Remove the module from the connector.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Inspiron 1526 Memory Module Replacement, Align the Notch: stap 4, afbeelding 1 van 2 Dell Inspiron 1526 Memory Module Replacement, Align the Notch: stap 4, afbeelding 2 van 2
      • Align the notch in the module edge connector with the tab in the connector slot.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell Inspiron 1526 Memory Module Replacement, Sliding the Module: stap 5, afbeelding 1 van 1
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
      Vraag FixBot
      Voeg opmerking toe
    6. Dell Inspiron 1526 Memory Module Replacement, Replace the Cover: stap 6, afbeelding 1 van 1
      • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer.
      • Replace the memory module cover.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
Terrence15
80.125 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
12.124 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 417
