Ga door naar hoofdinhoud
Dell Inspiron 1501 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 1501 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 1501 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 1501 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: stap 2, afbeelding 1 van 2 Dell Inspiron 1501 Keyboard Replacement, Hinge Cover: stap 2, afbeelding 2 van 2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Inspiron 1501 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 1501 Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Inspiron 1501 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 1501 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Don Dao
418 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 Lid van UMass Dartmouth, Team S2-G4, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G4
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 1,023
