Ga door naar hoofdinhoud
Dell Inspiron 1501 Display Replacement
Wat je nodig hebt
  1. Dell Inspiron 1501 Display Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 1501 Display Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 1501 Display Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the laptop facedown with the battery facing you.
    • Push the switch above the battery to the right and hold it in that position.
    • Lift the battery using the grip on the top and remove it from its socket.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Inspiron 1501 Display Replacement, Hinge Cover: stap 2, afbeelding 1 van 2 Dell Inspiron 1501 Display Replacement, Hinge Cover: stap 2, afbeelding 2 van 2
    • Open the laptop all the way, rotating the display so that it is level with the surface that you are working on.
    • Insert the spudger underneath the groove on the right side of the hinge cover.
    • Push up to pry the edge of the hinge cover out.
    • Lift up to release the hinge cover from the laptop, working from right to left.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Inspiron 1501 Display Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 1501 Display Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 1501 Display Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Remove the two 5mm JIS #1 screws from the top of the keyboard.
    • Lift the top of the keyboard up and pull the keyboard away from the laptop.
    • Be sure not to break the ribbon connector that attaches the keyboard to the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Inspiron 1501 Display Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 1501 Display Replacement: stap 4, afbeelding 2 van 2
    • Open the latch holding the ribbon from the top
    • Remove the keyboard from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Inspiron 1501 Display Replacement, Display: stap 5, afbeelding 1 van 2 Dell Inspiron 1501 Display Replacement, Display: stap 5, afbeelding 2 van 2
    • Close display and flip the laptop upside down.
    • Remove the two 8mm JIS #1 screws on the backplate that hold the display.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Inspiron 1501 Display Replacement: stap 6, afbeelding 1 van 1
    • From the back of the computer, remove the two screw covers.
    • Remove the two 8mm JIS #1 screws.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Inspiron 1501 Display Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 1501 Display Replacement: stap 7, afbeelding 2 van 2
    • Turn the laptop over and open the display.
    • Remove the two 5mm JIS #1 screws on the display hinge.
    Vraag FixBot
    Voeg opmerking toe
  8. Dell Inspiron 1501 Display Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron 1501 Display Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron 1501 Display Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the antenna cables from the Mini-Card.
    • Be careful not to knock the standby switch when disconnecting the cables as it is easily broken.
    • Loosen the JIS #1 screw on the display cable.
    • Pull the pull-tab straight up to disconnect the display cable from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  9. Dell Inspiron 1501 Display Replacement: stap 9, afbeelding 1 van 1
    • Remove the display from the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Luc-Anthony Breneville
183 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S2-G4, Simcock Spring 2018 Lid van UMass Dartmouth, Team S2-G4, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G4
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 1,325
