Ga door naar hoofdinhoud
Dell Inspiron 15 Ram (Memory Module) Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 15 Ram (Memory Module) Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Inspiron 15 Ram (Memory Module) Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): stap 3, afbeelding 1 van 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): stap 3, afbeelding 2 van 3 Dell Inspiron 15 Ram (Memory Module) Replacement, Ram  (Memory Module): stap 3, afbeelding 3 van 3
    • Remove the bottom cover by removing the 4 mm screw using a PH-0 Phillips screwdriver that secures the base cover to the laptop base.
    • Using the plastic opening tool, pry the base cover from the base.
    • Slide the base cover towards you and remove it from the base. Put it aside.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Inspiron 15 Ram (Memory Module) Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 15 Ram (Memory Module) Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 15 Ram (Memory Module) Replacement: stap 4, afbeelding 3 van 3
    • Using your fingertips, pry the vertical sides of the memory module apart until the piece pops out of place.
    • Slide the memory module out of its slot and lift it out of the laptop base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Edward Pacheco
852 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 5-8, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-8, Landers Spring 2016
UMASSD-LANDERS-S16S5G8
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 40
Altijd: 7,385
