Ga door naar hoofdinhoud
Dell Inspiron 15 7579 Speakers Replacement
Wat je nodig hebt
  1. Dell Inspiron 15 7579 Speakers Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Speakers Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15 7579 Speakers Replacement: stap 2, afbeelding 2 van 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Speakers Replacement, Battery: stap 3, afbeelding 1 van 2 Dell Inspiron 15 7579 Speakers Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
  5. Dell Inspiron 15 7579 Speakers Replacement, Speakers: stap 5, afbeelding 1 van 2 Dell Inspiron 15 7579 Speakers Replacement, Speakers: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • After battery is removed, locate the left and right speakers.
    • On the right speaker assembly, remove the pin connector using the tweezers.
  6. Dell Inspiron 15 7579 Speakers Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 15 7579 Speakers Replacement: stap 6, afbeelding 2 van 2
    • Use the metal spudger to pry off the right speaker assembly.
  7. Dell Inspiron 15 7579 Speakers Replacement: stap 7, afbeelding 1 van 1
    • Use a metal spudger to pry off left speaker assembly.
  8. Dell Inspiron 15 7579 Speakers Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 15 7579 Speakers Replacement: stap 8, afbeelding 2 van 2
    • Un-thread the wire by removing them from under the plastic clamps. No tools are required for this step. Repeat for both sides.
  9. Dell Inspiron 15 7579 Speakers Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 15 7579 Speakers Replacement: stap 9, afbeelding 2 van 2
    • Pull the adhesive cable away from the metal backing and push the right speaker assembly under it.
    • Remove the Velcro holding the speaker wire and remove the speakers from the device.
Conclusie
Inaki Madrigal
760 Reputatie
6 handleidingen geschreven
Cal Poly, Team S24-G9, Maness Spring 2018 Lid van Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,222
