Ga door naar hoofdinhoud
Dell Inspiron 14z Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 14z Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 3 Dell Inspiron 14z Hard Drive Replacement, Hard Drive: stap 1, afbeelding 3 van 3
    • Here is a Dell Inspiron 14z N411z with a defective hard drive.
    • On the back side is only one cover for the hard drive as well as the memory module.
    • Remove the Phillips screw on the bottom right corner of the cover.
  2. Dell Inspiron 14z Hard Drive Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 14z Hard Drive Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 14z Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to unsnap the cover from the back case.
    • Move the tool gently along the corner of the cover.
    • The screw that holds the cover on, has a spring clip that keeps the screw attached to the cover. during removal of the screw, this clip might come off.
  3. Dell Inspiron 14z Hard Drive Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 14z Hard Drive Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 14z Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • With the removal of the cover, the hard drive is immediately visible. Remove the four screws securing the hard drive bracket.
    • Slide the hard drive to the opposite end of the connector. This will free the connection.
  4. Dell Inspiron 14z Hard Drive Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 14z Hard Drive Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 14z Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Pull gently on the black tab on the hard drive. This will remove the drive and caddy from the computer.
    • Remove the two Phillips screws on the right side,
    • and the two Phillips screws on the left side.
  5. Dell Inspiron 14z Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • The hard drive is now removed from the caddy and the replacement can be installed.
Conclusie
oldturkey03
783.763 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
33 Leden
551 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 12,780
