Inleiding
Do you find your display is cracked, internally damaged, or covered in dead pixels? One solution can simply be replacing your screen.
Wat je nodig hebt
Use a spudger to pry the 6 rubber bumpers from the display.
Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
Gently pry the frame using a spudger.
Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
Use a spudger to loosen the frame from the top.
Lift up the black connector to detach the gold ribbon.
Squeeze the two metal clips located on the VGA cable.
Pull while squeezing the clips in order to remove the cable.
Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
Remove the metal brackets, one on each side, by gently pulling.
3 andere personen hebben deze handleiding voltooid.
