Ga door naar hoofdinhoud
Dell Dimension 4600 Sound Card Replacement
Wat je nodig hebt
    1. Dell Dimension 4600 Sound Card Replacement, Side Panel: stap 1, afbeelding 1 van 1
      • Locate the case cover latch on the back of the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Dimension 4600 Sound Card Replacement: stap 2, afbeelding 1 van 1
      • Using your index finger, slide and hold the cover latch down.
      • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Dimension 4600 Sound Card Replacement: stap 3, afbeelding 1 van 1
      • Grab the edge of the panel and slide it away from the case until it is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Dimension 4600 Sound Card Replacement, Sound Card: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Anti-Static Wrist Strap
      $7.95
      • Lay the computer flat on its side so that you are looking down on all of the components.
      • Very important at this point you connect your antistatic wrist strap to the chassis because the computer is no longer connected to ground at the power source. There is potential for static discharge which could destroy components.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Dimension 4600 Sound Card Replacement: stap 5, afbeelding 1 van 1
      • Locate the Sound Card and the screw attached to the Sound Card as shown in the picture.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Dimension 4600 Sound Card Replacement: stap 6, afbeelding 1 van 1
      • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Dimension 4600 Sound Card Replacement: stap 7, afbeelding 1 van 3 Dell Dimension 4600 Sound Card Replacement: stap 7, afbeelding 2 van 3 Dell Dimension 4600 Sound Card Replacement: stap 7, afbeelding 3 van 3
      • Locate and remove the white connector on the sound card by pulling on the black cable.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell Dimension 4600 Sound Card Replacement: stap 8, afbeelding 1 van 2 Dell Dimension 4600 Sound Card Replacement: stap 8, afbeelding 2 van 2
      • Grasp the Sound Card and pull it up and out of it's slot.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Arvind
395 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-10, Regan Fall 2011 Lid van Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 5,745
