Ga door naar hoofdinhoud
Dell Dimension 4600 Optical Drive Replacement
Wat je nodig hebt
    1. Dell Dimension 4600 Optical Drive Replacement, Side Panel: stap 1, afbeelding 1 van 1
      • Locate the case cover latch on the back of the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Dimension 4600 Optical Drive Replacement: stap 2, afbeelding 1 van 1
      • Using your index finger, slide and hold the cover latch down.
      • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Dimension 4600 Optical Drive Replacement: stap 3, afbeelding 1 van 1
      • Grab the edge of the panel and slide it away from the case until it is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Dimension 4600 Optical Drive Replacement, Optical Drive: stap 4, afbeelding 1 van 1
      • Locate the Optical Drive by finding it externally on the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Dimension 4600 Optical Drive Replacement: stap 5, afbeelding 1 van 2 Dell Dimension 4600 Optical Drive Replacement: stap 5, afbeelding 2 van 2
      • Press and hold the three levers located behind the front panel.
      • While holding the levers down, swing open the front panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Dimension 4600 Optical Drive Replacement: stap 6, afbeelding 1 van 1
      • Swing the front of the case open until it separates from the main case.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Dimension 4600 Optical Drive Replacement: stap 7, afbeelding 1 van 3 Dell Dimension 4600 Optical Drive Replacement: stap 7, afbeelding 2 van 3 Dell Dimension 4600 Optical Drive Replacement: stap 7, afbeelding 3 van 3
      • Lay the computer flat on it's side so that you are looking down on all of the components.
      • Locate the Drive 1 cable and where it is connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell Dimension 4600 Optical Drive Replacement: stap 8, afbeelding 1 van 1
      • Grasp the end of the Drive 1 cable connected to the motherboard and firmly pull upwards until it is removed.
      Vraag FixBot
      Voeg opmerking toe
    6. Dell Dimension 4600 Optical Drive Replacement: stap 9, afbeelding 1 van 2 Dell Dimension 4600 Optical Drive Replacement: stap 9, afbeelding 2 van 2
      • Locate the end of the Drive 1 cable connected to the optical drive.
      • Grasp the cable and pull firmly to disconnect it from the optical drive.
      Vraag FixBot
      Voeg opmerking toe
    7. Dell Dimension 4600 Optical Drive Replacement: stap 10, afbeelding 1 van 2 Dell Dimension 4600 Optical Drive Replacement: stap 10, afbeelding 2 van 2
      • Locate the screw on the optical drive.
      • Remove the 7.7 mm screw by using a Phillips #2 screw-driver.
      Vraag FixBot
      Voeg opmerking toe
    8. Dell Dimension 4600 Optical Drive Replacement: stap 11, afbeelding 1 van 1
      • Remove the optical drive by sliding it out of the front of the case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
13 andere personen hebben deze handleiding voltooid.
Eugene
216 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-10, Regan Fall 2011 Lid van Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 50
Altijd: 7,332
