Ga door naar hoofdinhoud
Dell Dimension 4600 Fan Replacement
    1. Dell Dimension 4600 Fan Replacement, Side Panel: stap 1, afbeelding 1 van 1
      • Locate the case cover latch on the back of the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Dimension 4600 Fan Replacement: stap 2, afbeelding 1 van 1
      • Using your index finger, slide and hold the cover latch down.
      • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Dimension 4600 Fan Replacement: stap 3, afbeelding 1 van 1
      • Grab the edge of the panel and slide it away from the case until it is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Dimension 4600 Fan Replacement, Fan: stap 4, afbeelding 1 van 1
      • Lay the computer flat on it's side so that you are looking down at all of the components.
      • Locate the fan and its black, red, and white power cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Dimension 4600 Fan Replacement: stap 5, afbeelding 1 van 1
      • Follow the power cable to the motherboard connection and remove it by pressing down on the clip.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Dimension 4600 Fan Replacement: stap 6, afbeelding 1 van 1
      • Locate the release clip on the side of the fan and hold it down with your thumb.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Dimension 4600 Fan Replacement: stap 7, afbeelding 1 van 1
      • While holding the release clip down, look on the outside of the case where the fan lies.
      • Using the four black notches as a reference, slide the fan towards the open side releasing the fan.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Tim
76 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-10, Regan Fall 2011 Lid van Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Leden
11 handleidingen geschreven
1Gids Commentaar
Thank you, the pictures are very good. My Dell 4600 had a green baffle that funneled the air through the heat sink fins. There is a little latch at the bottom which allows the this to swing open. Because the back of my PC is full of 13 years worth of cables, I did this without lying the PC down and without disconnecting the fan connector from the mother board. I am amazed at how quiet the PC is now.
pxcozzol - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 6,569
