Ga door naar hoofdinhoud
Dell Alienware M11x R3 2.5" Hard Drive Replacement
Wat je nodig hebt
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: stap 1, afbeelding 1 van 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: stap 1, afbeelding 2 van 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: stap 1, afbeelding 3 van 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: stap 2, afbeelding 1 van 1
    • Remove the three screws attaching the hard drive tray to the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 4, afbeelding 1 van 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Richard Maurice
534 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S3-G7, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G7, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G7
3 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 2,038
