Ga door naar hoofdinhoud
Dell Alienware 15 R3 Battery Replacement
Wat je nodig hebt
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: stap 1, afbeelding 1 van 3 Dell Alienware 15 R3 Battery Replacement, Back Case: stap 1, afbeelding 2 van 3 Dell Alienware 15 R3 Battery Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Alienware 15 R3 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Alienware 15 R3 Battery Replacement: stap 4, afbeelding 1 van 2 Dell Alienware 15 R3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Alienware 15 R3 Battery Replacement: stap 5, afbeelding 1 van 3 Dell Alienware 15 R3 Battery Replacement: stap 5, afbeelding 2 van 3 Dell Alienware 15 R3 Battery Replacement: stap 5, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove 10 screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Alienware 15 R3 Battery Replacement, Battery: stap 6, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Alienware 15 R3 Battery Replacement: stap 7, afbeelding 1 van 3 Dell Alienware 15 R3 Battery Replacement: stap 7, afbeelding 2 van 3 Dell Alienware 15 R3 Battery Replacement: stap 7, afbeelding 3 van 3
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jake Nelson
642 Reputatie
7 handleidingen geschreven
2Gids Commentaar
does not seem to be for my alienware r3 15 inch
Craig Anderson - Antwoord Deel
step 5 - you need to unscrew 10 screws, not 9. You missed the one in the center.
Mike Kravchenko - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 192
Altijd: 10,442
