Ga door naar hoofdinhoud
Dell Alienware 14 Memory Module Replacement
Wat je nodig hebt
  1. Dell Alienware 14 Memory Module Replacement, Close the Display: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Alienware 14 Memory Module Replacement, Remove the Screws: stap 2, afbeelding 1 van 2 Dell Alienware 14 Memory Module Replacement, Remove the Screws: stap 2, afbeelding 2 van 2
    • Remove the screws that secure the base cover to the computer base.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Alienware 14 Memory Module Replacement, Slide and Lift the Base Cover: stap 3, afbeelding 1 van 1
    • Slide and lift the base cover off the computer base.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Alienware 14 Memory Module Replacement, Align the Tabs: stap 4, afbeelding 1 van 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Alienware 14 Memory Module Replacement, Replace the Screws: stap 5, afbeelding 1 van 1
    • Replace the screws that secure the base cover to the computer base.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: stap 6, afbeelding 1 van 1
    • Turn the computer over and open the display.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Alienware 14 Memory Module Replacement, Disconnecting the Battery Cable: stap 7, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  8. Dell Alienware 14 Memory Module Replacement, Remove the Screws: stap 8, afbeelding 1 van 1
    • Remove the screws that secure the battery to the computer base.
    Vraag FixBot
    Voeg opmerking toe
  9. Dell Alienware 14 Memory Module Replacement, Using the Battery Cable: stap 9, afbeelding 1 van 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
    Vraag FixBot
    Voeg opmerking toe
  10. Dell Alienware 14 Memory Module Replacement, Turn the Computer Over: stap 10, afbeelding 1 van 1
    • Turn the computer over and open the display as far as possible.
    Vraag FixBot
    Voeg opmerking toe
  11. Dell Alienware 14 Memory Module Replacement, The Power Button: stap 11, afbeelding 1 van 1
    • Press and hold the power button for five seconds to ground the system board.
    Vraag FixBot
    Voeg opmerking toe
    • Close the display and turn the computer over.
    Vraag FixBot
    Voeg opmerking toe
  12. Dell Alienware 14 Memory Module Replacement, Align the Tabs: stap 13, afbeelding 1 van 1
    • Align the tabs on the NEW battery with the slots on the computer base.
    Vraag FixBot
    Voeg opmerking toe
  13. Dell Alienware 14 Memory Module Replacement, Align the Screw Holes: stap 14, afbeelding 1 van 1
    • Align the screw holes on the battery with the screw holes on the computer base.
    Vraag FixBot
    Voeg opmerking toe
  14. Dell Alienware 14 Memory Module Replacement, Replace the Screws: stap 15, afbeelding 1 van 1
    • Replace the screws that secure the battery to the computer base.
    Vraag FixBot
    Voeg opmerking toe
  15. Dell Alienware 14 Memory Module Replacement, Connect the Battery Cable: stap 16, afbeelding 1 van 1
    • Connect the battery cable to the system-board connector.
    Vraag FixBot
    Voeg opmerking toe
  16. Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: stap 17, afbeelding 1 van 3 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: stap 17, afbeelding 2 van 3 Dell Alienware 14 Memory Module Replacement, Popping up the Memory Module: stap 17, afbeelding 3 van 3
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    Vraag FixBot
    Voeg opmerking toe
  17. Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: stap 18, afbeelding 1 van 2 Dell Alienware 14 Memory Module Replacement, Remove the Memory Module: stap 18, afbeelding 2 van 2
    • Remove the memory module from the memory-module connector.
    Vraag FixBot
    Voeg opmerking toe
  18. Dell Alienware 14 Memory Module Replacement, Align the Notch: stap 19, afbeelding 1 van 2 Dell Alienware 14 Memory Module Replacement, Align the Notch: stap 19, afbeelding 2 van 2
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
    Vraag FixBot
    Voeg opmerking toe
  19. Dell Alienware 14 Memory Module Replacement, Slide the Memory Module: stap 20, afbeelding 1 van 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Terrence15
80.125 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.003 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 40
Altijd: 539
