Ga door naar hoofdinhoud
DeWalt DWE4011 Power Cable Replacement
Wat je nodig hebt
    1. DeWalt DWE4011 Power Cable Replacement, Power Cord: stap 1, afbeelding 1 van 1
      • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
      Vraag FixBot
      Voeg opmerking toe
    2. DeWalt DWE4011 Power Cable Replacement: stap 2, afbeelding 1 van 2 DeWalt DWE4011 Power Cable Replacement: stap 2, afbeelding 2 van 2
      • Remove bottom casing by separating the end handle away from the main casing.
      Vraag FixBot
      Voeg opmerking toe
    3. DeWalt DWE4011 Power Cable Replacement: stap 3, afbeelding 1 van 2 DeWalt DWE4011 Power Cable Replacement: stap 3, afbeelding 2 van 2
      • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
      Vraag FixBot
      Voeg opmerking toe
    4. DeWalt DWE4011 Power Cable Replacement: stap 4, afbeelding 1 van 1
      • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
      Vraag FixBot
      Voeg opmerking toe
    5. DeWalt DWE4011 Power Cable Replacement: stap 5, afbeelding 1 van 2 DeWalt DWE4011 Power Cable Replacement: stap 5, afbeelding 2 van 2
      • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
      Vraag FixBot
      Voeg opmerking toe
    6. DeWalt DWE4011 Power Cable Replacement: stap 6, afbeelding 1 van 2 DeWalt DWE4011 Power Cable Replacement: stap 6, afbeelding 2 van 2
      • Locate the terminals with the two white cables attached and disconnect both.
      • These cables are connected to the outer terminals; connect as such during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    7. DeWalt DWE4011 Power Cable Replacement: stap 7, afbeelding 1 van 2 DeWalt DWE4011 Power Cable Replacement: stap 7, afbeelding 2 van 2
      • Remove the entirety of the cable housing from the device casing.
      • The two wires coming from the power cable should still be connected to electrical housing at this point.
      Vraag FixBot
      Voeg opmerking toe
    8. DeWalt DWE4011 Power Cable Replacement: stap 8, afbeelding 1 van 1
      • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
      • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Where can I find a replacement power cord?
Ethan Sligar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 65
Altijd: 4,796
