Ga door naar hoofdinhoud
DeWalt DWD112 Power Cord Replacement
Wat je nodig hebt
    1. DeWalt DWD112 Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 1
      • Remove seven TR20 Torx Security screws from the side of the drill.
      Vraag FixBot
      Voeg opmerking toe
    2. DeWalt DWD112 Power Cord Replacement: stap 2, afbeelding 1 van 1
      • Remove the top cover to reveal the inside of the drill.
      • Set the top cover of the drill aside.
      Vraag FixBot
      Voeg opmerking toe
    3. DeWalt DWD112 Power Cord Replacement: stap 3, afbeelding 1 van 1
      • The power cord and the trigger act as a single part and must be replaced together.
      • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
      Vraag FixBot
      Voeg opmerking toe
    4. DeWalt DWD112 Power Cord Replacement: stap 4, afbeelding 1 van 1
      • Disconnect the second connected wire from the top of the trigger box.
      Vraag FixBot
      Voeg opmerking toe
    5. DeWalt DWD112 Power Cord Replacement: stap 5, afbeelding 1 van 1
      • Lift the trigger box up to reveal the bottom side.
      • Disconnect the first connected wire from the bottom of the trigger box.
      Vraag FixBot
      Voeg opmerking toe
    6. DeWalt DWD112 Power Cord Replacement: stap 6, afbeelding 1 van 1
      • Disconnect the last wire from the trigger box using the same method from the previous step.
      Vraag FixBot
      Voeg opmerking toe
    7. DeWalt DWD112 Power Cord Replacement: stap 7, afbeelding 1 van 1
      • After all four wires are disconnected, the trigger and power cord are separated from the drill.
      • The power cord and trigger can be set aside if further disassembly is required.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Samantha McSweeney
407 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-3, Isaacson Spring 2016 Lid van UMass Dartmouth, Team 2-3, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G3
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 1,644
