Ga door naar hoofdinhoud
DeWalt DCS380 Trigger assembly Replacement
Wat je nodig hebt
    1. DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: stap 1, afbeelding 1 van 2 DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: stap 1, afbeelding 2 van 2
      • Remove the battery before dissasembly.
      • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
      • Remove the six M3.63x19 T15 screws from the grip.
      Vraag FixBot
      Voeg opmerking toe
    2. DeWalt DCS380 Trigger assembly Replacement: stap 2, afbeelding 1 van 3 DeWalt DCS380 Trigger assembly Replacement: stap 2, afbeelding 2 van 3 DeWalt DCS380 Trigger assembly Replacement: stap 2, afbeelding 3 van 3
      • Remove the top half of the grip.
      • Turn the saw over and locate the power connectors to the motor.
      • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
      • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
      Vraag FixBot
      Voeg opmerking toe
    1. DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: stap 3, afbeelding 1 van 3 DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: stap 3, afbeelding 2 van 3 DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: stap 3, afbeelding 3 van 3
      • Take note of the position of the battery tension spring and safety switch before removal.
      • Lift the trigger assembly out of the grip.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 45
Altijd: 1,922
