Ga door naar hoofdinhoud
DROCON Ninja Propeller Replacement
  1. DROCON Ninja Propeller Replacement, Battery: stap 1, afbeelding 1 van 3 DROCON Ninja Propeller Replacement, Battery: stap 1, afbeelding 2 van 3 DROCON Ninja Propeller Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Propeller Replacement, Propeller: stap 2, afbeelding 1 van 2 DROCON Ninja Propeller Replacement, Propeller: stap 2, afbeelding 2 van 2
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
  3. DROCON Ninja Propeller Replacement: stap 3, afbeelding 1 van 3 DROCON Ninja Propeller Replacement: stap 3, afbeelding 2 van 3 DROCON Ninja Propeller Replacement: stap 3, afbeelding 3 van 3
    • Take note of the letter printed on the bottom of the propeller. Make sure the replacement propeller has the same letter.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
Conclusie
4 opmerkingen
can we buy an extra battery?
Orlay Gutierrez - Antwoord
can we buy an extra battery for the roconDC-014
hi i have the red & bleu drocon dc-014 & wold like to order the white drocon dc-014 white drone or white body cover
tank you! & happy new year!!!
claude demers - Antwoord
i both drocon dc-014 blue & red wold like by the white drocon dc-014 or uper casse
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 1,762
