Ga door naar hoofdinhoud
DR.J Professional HI-04 Lens Replacement
Wat je nodig hebt
  1. DR.J Professional HI-04 Lens Replacement, Lens: stap 1, afbeelding 1 van 3 DR.J Professional HI-04 Lens Replacement, Lens: stap 1, afbeelding 2 van 3 DR.J Professional HI-04 Lens Replacement, Lens: stap 1, afbeelding 3 van 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: stap 2, afbeelding 1 van 3 DR.J Professional HI-04 Lens Replacement: stap 2, afbeelding 2 van 3 DR.J Professional HI-04 Lens Replacement: stap 2, afbeelding 3 van 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: stap 3, afbeelding 1 van 2 DR.J Professional HI-04 Lens Replacement: stap 3, afbeelding 2 van 2
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: stap 4, afbeelding 1 van 2 DR.J Professional HI-04 Lens Replacement: stap 4, afbeelding 2 van 2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: stap 5, afbeelding 1 van 2 DR.J Professional HI-04 Lens Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the cover of the lens.
Conclusie
Kory Lajoie
127 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Lid van UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Leden
5 handleidingen geschreven
1Gids Commentaar
how to replace lcd
Rael Sañosa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 34
Altijd: 710
