Ga door naar hoofdinhoud
DOSS SoundBox Motherboard Replacement
Wat je nodig hebt
    1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: stap 1, afbeelding 1 van 3 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: stap 1, afbeelding 2 van 3 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: stap 1, afbeelding 3 van 3
      • Use a small plastic opening tool to gently lift the side of the grille.
      • Gently slide the tool to the front of the speaker.
      • Repeat the process on the bottom of the grille.
      • Gently pull the grille off of the speaker enclosure.
      • Pry with caution, for the grille is fragile.
      Vraag FixBot
      Voeg opmerking toe
    1. DOSS SoundBox Motherboard Replacement, Speaker: stap 2, afbeelding 1 van 2 DOSS SoundBox Motherboard Replacement, Speaker: stap 2, afbeelding 2 van 2
      • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
      • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
      • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
      • Using a Magnetic Mat throughout this process will help prevent losing screws.
      Vraag FixBot
      Voeg opmerking toe
    2. DOSS SoundBox Motherboard Replacement: stap 3, afbeelding 1 van 2 DOSS SoundBox Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
      Vraag FixBot
      Voeg opmerking toe
    3. DOSS SoundBox Motherboard Replacement: stap 4, afbeelding 1 van 2 DOSS SoundBox Motherboard Replacement: stap 4, afbeelding 2 van 2
      • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
      • The speakers are ready to be removed and replaced.
      • Ensure that the device is turned off when handling bare wire.
      • Soldering iron is very hot.
      Vraag FixBot
      Voeg opmerking toe
    1. DOSS SoundBox Motherboard Replacement, Battery: stap 5, afbeelding 1 van 2 DOSS SoundBox Motherboard Replacement, Battery: stap 5, afbeelding 2 van 2
      • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
      • Use a magnetic mat to prevent the loss of screws.
      Vraag FixBot
      Voeg opmerking toe
    2. DOSS SoundBox Motherboard Replacement: stap 6, afbeelding 1 van 2 DOSS SoundBox Motherboard Replacement: stap 6, afbeelding 2 van 2
      • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
      • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. DOSS SoundBox Motherboard Replacement: stap 7, afbeelding 1 van 1
      • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
      • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
      • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
      Vraag FixBot
      Voeg opmerking toe
    4. DOSS SoundBox Motherboard Replacement: stap 8, afbeelding 1 van 1
      • De-solder the connections from the battery to the circuit board.
      • If you do not already have a replacement battery, you can purchase one here.
      Vraag FixBot
      Voeg opmerking toe
    1. DOSS SoundBox Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
      • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
      • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
      • Be sure not to apply excessive force on the ribbon connector, as it can break.
      • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    2. DOSS SoundBox Motherboard Replacement: stap 10, afbeelding 1 van 2 DOSS SoundBox Motherboard Replacement: stap 10, afbeelding 2 van 2
      • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
      Vraag FixBot
      Voeg opmerking toe
    3. DOSS SoundBox Motherboard Replacement: stap 11, afbeelding 1 van 3 DOSS SoundBox Motherboard Replacement: stap 11, afbeelding 2 van 3 DOSS SoundBox Motherboard Replacement: stap 11, afbeelding 3 van 3
      • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
      • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
      • Using your fingers, you can now remove the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
6Gids Commentaar
Cassandra, the million dollar question is dWhere can i buy the motherboard for the SiundBox Doos.
please let me know at rubenalexander2611@hotmail.com, ahora todo lo mandan de la china please, a ver si me das una pagina web.
Ruben Diaz - Antwoord Deel
As Cassandra said before,,,,WHere we can find the parts??? is it any possibilities ?
bunker1312@gmail.com
bunker1312 - Antwoord Deel
Where to buy your motherboard for doss torch Bluetooth speaker
smoothjobbrian - Antwoord Deel
Ffs, Where do you get the board? Pretty useless writeup if there's no known location to aquire parts.
Christopher Cox - Antwoord Deel
I have taken the motherboard out. Where can I purchase another one as I don't see any link for that?
Paul Doran - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 80
Altijd: 6,585
