Ga door naar hoofdinhoud
DOSS SoundBox Battery Replacement
Wat je nodig hebt
  1. DOSS SoundBox Battery Replacement, Battery: stap 1, afbeelding 1 van 2 DOSS SoundBox Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
    Vraag FixBot
    Voeg opmerking toe
  2. DOSS SoundBox Battery Replacement: stap 2, afbeelding 1 van 2 DOSS SoundBox Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. DOSS SoundBox Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
    Vraag FixBot
    Voeg opmerking toe
  4. DOSS SoundBox Battery Replacement: stap 4, afbeelding 1 van 1
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Milad Etemadi - Antwoord Deel
Hi. Thanks for the guide! Can you please let me know how to remove the existing batt, I don’t know if it’s glued or sthing but I can’t take it out, I m stuck there. Tks !!
Philly newrocker - Antwoord Deel
Did you manage to get it removed? I don’t know any more details than what this guide offered, but if it is glued in, isopropyl alcohol or some low heat are usually quite helpful. Make sure the battery is drained beforehand, of course, though I doubt it’ll be an issue since you’re trying to replace the battery, most likely because it’s not holding a charge anymore. If you use isopropyl, you can get fairly liberal with it without having to worry about damaging anything so long as you don’t get any on the speakers because the glue used to hold them together can desolve causing separation which would ruin the sound and would need repair.
Thousand Sunny - Antwoord Deel
Link for Battery Replacement is broken.
Michael Scibetta - Antwoord Deel
I believe this is the new link to replacement battery
Tenergy-37-2200-pcb
Fixer245 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 132
Altijd: 15,147
