Ga door naar hoofdinhoud
DOSS SoundBox Base-plate Replacement
Wat je nodig hebt
    1. DOSS SoundBox Base-plate Replacement, Base-plate: stap 1, afbeelding 1 van 3 DOSS SoundBox Base-plate Replacement, Base-plate: stap 1, afbeelding 2 van 3 DOSS SoundBox Base-plate Replacement, Base-plate: stap 1, afbeelding 3 van 3
      • Locate the four 3/32" screws on the bottom of your device.
      • Using a JIS #00 screwdriver, remove the four 3/32" screws.
      • After removing the screws, lift the cover off of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. DOSS SoundBox Base-plate Replacement: stap 2, afbeelding 1 van 1
      • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
      • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
      • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
      Vraag FixBot
      Voeg opmerking toe
    3. DOSS SoundBox Base-plate Replacement: stap 3, afbeelding 1 van 1
      • Lift the base-plate off of the enclosure.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 57
Altijd: 2,681
