Ga door naar hoofdinhoud
DJI Phantom Propeller Replacement
Wat je nodig hebt
  1. DJI Phantom Propeller Replacement, Open the Battery Compartment: stap 1, afbeelding 1 van 3 DJI Phantom Propeller Replacement, Open the Battery Compartment: stap 1, afbeelding 2 van 3 DJI Phantom Propeller Replacement, Open the Battery Compartment: stap 1, afbeelding 3 van 3
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Propeller Replacement, Remove the Battery: stap 2, afbeelding 1 van 3 DJI Phantom Propeller Replacement, Remove the Battery: stap 2, afbeelding 2 van 3 DJI Phantom Propeller Replacement, Remove the Battery: stap 2, afbeelding 3 van 3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Propeller Replacement, Disconnect the Battery: stap 3, afbeelding 1 van 2 DJI Phantom Propeller Replacement, Disconnect the Battery: stap 3, afbeelding 2 van 2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: stap 4, afbeelding 1 van 2 DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: stap 4, afbeelding 2 van 2
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: stap 5, afbeelding 1 van 3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: stap 5, afbeelding 2 van 3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: stap 5, afbeelding 3 van 3
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom Propeller Replacement, Unscrewing Black Collets: stap 6, afbeelding 1 van 3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: stap 6, afbeelding 2 van 3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: stap 6, afbeelding 3 van 3
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom Propeller Replacement, Remove the Propeller: stap 7, afbeelding 1 van 3 DJI Phantom Propeller Replacement, Remove the Propeller: stap 7, afbeelding 2 van 3 DJI Phantom Propeller Replacement, Remove the Propeller: stap 7, afbeelding 3 van 3
    • Gently press down the motor shaft and lift the propeller up to remove it.
Conclusie
David Hoyt
4.053 Reputatie
41 handleidingen geschreven
Cal Poly, Team 25-89, Amido Spring 2010 Lid van Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Leden
61 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,315
