Ga door naar hoofdinhoud
DJI Phantom 3 Standard Remote Controller Joysticks Replacement
Wat je nodig hebt
  1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: stap 1, afbeelding 1 van 2 DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: stap 1, afbeelding 2 van 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 2, afbeelding 1 van 1
    • On the inside of the controller, remove the four 11 mm screws that cover the base housing of the joystick.
  3. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 3, afbeelding 1 van 3 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 3, afbeelding 2 van 3 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 3, afbeelding 3 van 3
    • Inside the base housing, remove the two 9 mm screws that secure the joystick brace piece on both the left and right side of the stick.
    • Remove the braces on the left and right sides of the joystick to reach the circuit board piece on the left.
    • Detach the circuit board piece.
  4. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 4, afbeelding 1 van 2 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 4, afbeelding 2 van 2
    • Separate the other circuit board piece from the joystick connection using a plastic spudger.
    • The circuit board is wired through glue. If the plastic spudger is unable to pry the glue off, use the metal spudger as a last resort.
    • Take the joystick module itself and remove the four 8 mm screws that connect the joystick to the housing.
    • Unscrew the thumb stick from the module if a replacement is not needed.
  5. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: stap 5, afbeelding 1 van 1
    • Remove the joystick.
Conclusie
Maddie McCoy
229 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 45
