Inleiding
In this guide you will remove the glue on the wires, desolder the wires connecting the LED to the control board and remove the LED from the drone.
Wat je nodig hebt
With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
Press the tab on the side of the connector and pull up on the cable.
Continue to remove the shell the rest of the way.
Follow the red,yellow and black wires from the LED to where they connect on the control board.
Scrape off the glue with a plastic opening tool. Use a metal opening tool if needed.
Desolder the red, yellow and black wires that connect the LED to the control board. Check out the link below for more information on desoldering. Desoldering Information
3 andere personen hebben deze handleiding voltooid.
