Ga door naar hoofdinhoud
DJI Phantom 2 Vision+ Propellers Removal
Wat je nodig hebt
  1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: stap 1, afbeelding 1 van 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: stap 1, afbeelding 2 van 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: stap 1, afbeelding 3 van 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ Propellers Removal, Propellers: stap 2, afbeelding 1 van 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: stap 3, afbeelding 1 van 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: stap 3, afbeelding 2 van 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: stap 3, afbeelding 3 van 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: stap 4, afbeelding 1 van 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: stap 4, afbeelding 2 van 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: stap 4, afbeelding 3 van 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
Conclusie
5 andere personen hebben deze handleiding voltooid.
David Hoyt
4.053 Reputatie
41 handleidingen geschreven
Cal Poly, Team 25-89, Amido Spring 2010 Lid van Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Leden
61 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 7,362
