Inleiding
This is a replacement guide for the DJI Mini 2's propeller blades.
The propellers are on the DJI Mini 2 help the drone generate lift for the drone when it is flying. A drone propeller will need to be replaced if the propeller is damaged and causes the drone to hover in an inconsistent way.
Wat je nodig hebt
Open up the propeller arms to make it easier to access the propeller blades.
Then, place the drone on a flat surface.
Bijna klaar!
Conclusie
