Ga door naar hoofdinhoud
DJI Mavic Pro Upper Shell Replacement
Wat je nodig hebt
    1. DJI Mavic Pro Upper Shell Replacement, Battery: stap 1, afbeelding 1 van 3 DJI Mavic Pro Upper Shell Replacement, Battery: stap 1, afbeelding 2 van 3 DJI Mavic Pro Upper Shell Replacement, Battery: stap 1, afbeelding 3 van 3
      • Grab both sides of the battery.
      • Pinch the releasing buttons on both sides of the battery.
      • Lift the battery up and out.
      Vraag FixBot
      Voeg opmerking toe
    1. DJI Mavic Pro Upper Shell Replacement, Upper Shell: stap 2, afbeelding 1 van 1
      • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. DJI Mavic Pro Upper Shell Replacement: stap 3, afbeelding 1 van 1
      • Flip the drone over so that the gimbal is facing up.
      • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    3. DJI Mavic Pro Upper Shell Replacement: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Remove the two small panel pieces near the gimbal case with the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    4. DJI Mavic Pro Upper Shell Replacement: stap 5, afbeelding 1 van 1
      • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    5. DJI Mavic Pro Upper Shell Replacement: stap 6, afbeelding 1 van 1
      • Flip the drone back over so the upper shell is facing up.
      • Pry off the upper shell with a nylon spudger.
      • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
      Vraag FixBot
      Voeg opmerking toe
    6. DJI Mavic Pro Upper Shell Replacement: stap 7, afbeelding 1 van 1
      • Remove the white connector at the back of the flight controller board by gently pulling at the base.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Mondona Behroozian
1.716 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G3, White Fall 2018 Lid van Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Leden
20 handleidingen geschreven
2Gids Commentaar
Well done, good instructions - are the two screws under the tabs shorter than the others from the shell?
Lazaro Hernandez - Antwoord Deel
Awesome descriptions were perfect except for saying there is 4 acres to be removed under the tabs behind the gimbal. Theirs only 2
shaun.cunningham - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 80
Altijd: 6,799
