Gereedschap
Onderdelen
Remove power cord, network cable, etc.
Remove paper tray and rear paper guide.
Slide the cover of the expansion slot backwards and open.
Unhook the flap from the lower hinge.
Loosen and remove front screws (1x top, 1x bottom) and rear (1x top, 1x bottom) with Phillips screwdriver.
Carefully loosen the front and rear housing parts with a light pull from the left.
Remove the left housing by carefully loosening the 3 clamps on the floor.
Follow the steps in reverse order to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
