Ga door naar hoofdinhoud
CyberPowerPC RGB 7 Color USB Outlet Replacement
Wat je nodig hebt
  1. CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: stap 1, afbeelding 1 van 2 CyberPowerPC RGB 7 Color USB Outlet Replacement, Plastic Casing: stap 1, afbeelding 2 van 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
    Vraag FixBot
    Voeg opmerking toe
  2. CyberPowerPC RGB 7 Color USB Outlet Replacement: stap 2, afbeelding 1 van 2 CyberPowerPC RGB 7 Color USB Outlet Replacement: stap 2, afbeelding 2 van 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
    Vraag FixBot
    Voeg opmerking toe
  3. CyberPowerPC RGB 7 Color USB Outlet Replacement: stap 3, afbeelding 1 van 1
    • Lift up and remove the plastic casing.
    Vraag FixBot
    Voeg opmerking toe
  4. CyberPowerPC RGB 7 Color USB Outlet Replacement, LED Backlight: stap 4, afbeelding 1 van 1
    • Remove the metal backing located directly underneath the white plastic casing.
    Vraag FixBot
    Voeg opmerking toe
  5. CyberPowerPC RGB 7 Color USB Outlet Replacement: stap 5, afbeelding 1 van 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. CyberPowerPC RGB 7 Color USB Outlet Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the LED board, which should now come free from the casing.
    Vraag FixBot
    Voeg opmerking toe
  7. CyberPowerPC RGB 7 Color USB Outlet Replacement, USB Outlet: stap 7, afbeelding 1 van 1
    • Remove the motherboard and its attached cable from the plastic casing. The cord should now be free and can be replaced.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Katherine Von Braunsberg
377 Reputatie
3 handleidingen geschreven
USF Tampa, Team S15-G2, Boczar Spring 2018 Lid van USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 46
Altijd: 1,287
