Inleiding
The LED backlight may burn out, causing the backlight to cease working properly. This guide will demonstrate how to replace the LED backlight.
Wat je nodig hebt
Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
Remove the metal backing located directly underneath the white plastic casing.
