Ga door naar hoofdinhoud
Curtain Rod Bracket Replacement
Wat je nodig hebt
  1. Curtain Rod Bracket Replacement, Bracket: stap 1, afbeelding 1 van 2 Curtain Rod Bracket Replacement, Bracket: stap 1, afbeelding 2 van 2
    • If the bracket is still partially attached, use a screwdriver to remove the remaining screw(s), then remove the bracket from the wall completely.
    Vraag FixBot
  2. Curtain Rod Bracket Replacement: stap 2, afbeelding 1 van 2 Curtain Rod Bracket Replacement: stap 2, afbeelding 2 van 2
    • Observe the hole of the screw(s) that was ripped out of the wall.
    • Determine whether the plastic anchor will fit in the current size of the hole.
    • If the hole is smaller than the anchor, continue to Step 3. If the hole is bigger, complete this guide on patching a hole in dry wall.
    Vraag FixBot
  3. Curtain Rod Bracket Replacement: stap 3, afbeelding 1 van 2 Curtain Rod Bracket Replacement: stap 3, afbeelding 2 van 2
    • Use a ¼ inch drill bit to drill the hole(s) that the anchor will be placed into. Drill into the wall and continue drilling as you pull out of the wall.
    • Avoid placing hands near the drill bit while in use. If you have medium to long-length hair, tie your hair back to avoid possible injury.
    Vraag FixBot
  4. Curtain Rod Bracket Replacement: stap 4, afbeelding 1 van 3 Curtain Rod Bracket Replacement: stap 4, afbeelding 2 van 3 Curtain Rod Bracket Replacement: stap 4, afbeelding 3 van 3
    • Hammer the hollow wall anchor(s) into the hole until flush with the drywall.
    Vraag FixBot
  5. Curtain Rod Bracket Replacement: stap 5, afbeelding 1 van 1
    • Paint the wall anchor and any surrounding area that has been damaged so that it matches the wall.
    Vraag FixBot
  6. Curtain Rod Bracket Replacement: stap 6, afbeelding 1 van 2 Curtain Rod Bracket Replacement: stap 6, afbeelding 2 van 2
    • Screw the bracket into the anchor(s) with a screwdriver. The bracket will be secured to the wall.
    Vraag FixBot
  7. Curtain Rod Bracket Replacement: stap 7, afbeelding 1 van 2 Curtain Rod Bracket Replacement: stap 7, afbeelding 2 van 2
    • Touch up with paint if necessary.
    Vraag FixBot
  8. Curtain Rod Bracket Replacement: stap 8, afbeelding 1 van 2 Curtain Rod Bracket Replacement: stap 8, afbeelding 2 van 2
    • Rehang your curtain rod and curtains by placing the rod onto the bracket.
    Vraag FixBot
Conclusie
Enjoy your renewed privacy!
Ashtyn Drake
157 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 73
Altijd: 1,399
