Inleiding
This guide will show you how to replace the switch board inside your Cuisinart Smart Stick. If power is not being supplied to the Smart Stick, the switch board could be unresponsive.
Wat je nodig hebt
Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
After prying these off, the screws will be exposed.
Één andere persoon heeft deze handleiding voltooid.
