Ga door naar hoofdinhoud
Cuisinart DCC-1200 Heating Element Replacement
Wat je nodig hebt
  1. Cuisinart DCC-1200  Heating Element Replacement, Heating Element: stap 1, afbeelding 1 van 3 Cuisinart DCC-1200  Heating Element Replacement, Heating Element: stap 1, afbeelding 2 van 3 Cuisinart DCC-1200  Heating Element Replacement, Heating Element: stap 1, afbeelding 3 van 3
    • Flip the coffee maker over so the bottom is facing up.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Cuisinart DCC-1200  Heating Element Replacement: stap 2, afbeelding 1 van 3 Cuisinart DCC-1200  Heating Element Replacement: stap 2, afbeelding 2 van 3 Cuisinart DCC-1200  Heating Element Replacement: stap 2, afbeelding 3 van 3
    • Squeeze the hose clamps together and begin moving the metal clamp away from the heating element.
    • Gently pull on the loose hose to remove it from the heating element.
  3. Cuisinart DCC-1200  Heating Element Replacement: stap 3, afbeelding 1 van 2 Cuisinart DCC-1200  Heating Element Replacement: stap 3, afbeelding 2 van 2
    • Repeat previous step to disconnect the other attached water hose.
  4. Cuisinart DCC-1200  Heating Element Replacement: stap 4, afbeelding 1 van 2 Cuisinart DCC-1200  Heating Element Replacement: stap 4, afbeelding 2 van 2
    • Use the bit driver with the extension attachment with the PH1 Phillips bit to remove the two 18mm long screws on heating element plate.
  5. Cuisinart DCC-1200  Heating Element Replacement: stap 5, afbeelding 1 van 2 Cuisinart DCC-1200  Heating Element Replacement: stap 5, afbeelding 2 van 2
    • If heating contacts are connected, use a soldering iron to desolder the bond between metal contact points.
    • Solder iron can cause burns if used improperly
  6. Cuisinart DCC-1200  Heating Element Replacement: stap 6, afbeelding 1 van 3 Cuisinart DCC-1200  Heating Element Replacement: stap 6, afbeelding 2 van 3 Cuisinart DCC-1200  Heating Element Replacement: stap 6, afbeelding 3 van 3
    • Remove the heating element clamp and set aside to access the heating element.
    • Gently squeeze and pull up on metal clamp attached to the heating element.
  7. Cuisinart DCC-1200  Heating Element Replacement: stap 7, afbeelding 1 van 1
    • Remove and replace the defective heating element.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Austin Wheaton
861 Reputatie
4 handleidingen geschreven
UW Stout, Team S8-G1, Ogden Spring 2018 Lid van UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Leden
5 handleidingen geschreven
19 opmerkingen
Where do you find a replacement heating element?
Evan Dunville - Antwoord
Finding the replacement heater element is the real challenge:)
vvaccaro - Antwoord
I have a Cusinart DCC-2600 coffee maker that has stopped heating. I suspect the heating element needs replacing. The bottom of the maker looks very similar to the DCC-1200 shown above, but the 4 screws that hold the bottom on my model do not have any torx heads. They feel more like a rivet?!
Is this to make it not serviceable or am I missing something? If anyone has a suggestion, please respond
Dave Schultz - Antwoord
Hi Dave,
Here,  I’ve Cuisinart DCC-1400 coffee maker but the 4 screws  on bottom is a torx with the pin in the center.
Check this , you need probably a torx driver with the hole in the center !
Jos
Jos -
Agree - any assistance in finding the replacement heating element would be most helpful. I have this coffee maker, and the metal clamp holding the heating element in place corroded through. Now the hotplate falls away from the bottom of the coffee maker. I’d like to replace the heating element and I assume it comes with the clamp in place - but cuisinart does not make any internal parts available to online parts retailers. Thanks!
David Miller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 124
Altijd: 16,608
