Ga door naar hoofdinhoud
CrystalView NB4-35788 Battery Replacement
Wat je nodig hebt
  1. CrystalView NB4-35788 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Battery Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery using a plastic spudger.
    • Do not use a metal spudger, as this can damage the device.
  5. CrystalView NB4-35788 Battery Replacement: stap 5, afbeelding 1 van 2 CrystalView NB4-35788 Battery Replacement: stap 5, afbeelding 2 van 2
    • Peel back the yellow film on the old battery to expose the red and black wires
    • De-solder these wires to disconnect the old battery
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Conclusie
Courtney Clark
218 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 300
