Ga door naar hoofdinhoud
CrystalView NB4-35788 Auxiliary Speakers Replacement
Wat je nodig hebt
  1. CrystalView NB4-35788 Auxiliary Speakers Replacement, Auxiliary Speakers: stap 1, afbeelding 1 van 1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Auxiliary Speakers Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Auxiliary Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Auxiliary Speakers Replacement: stap 4, afbeelding 1 van 1
    • Two speakers can be found on the device, one in the lower-right corner and one in the lower left-corner.
  5. CrystalView NB4-35788 Auxiliary Speakers Replacement: stap 5, afbeelding 1 van 1
    • Gently pull up on the speaker to remove it. Repeat this for the other speaker.
  6. CrystalView NB4-35788 Auxiliary Speakers Replacement: stap 6, afbeelding 1 van 2 CrystalView NB4-35788 Auxiliary Speakers Replacement: stap 6, afbeelding 2 van 2
    • De-solder the red and black wires to disconnect the old speaker.
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Conclusie
Alex Stokes
101 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 141
