Inleiding
In this guide, you will be able to remove the motherboard from a creative ZiiO and use a soldering iron while doing so.
Wat je nodig hebt
Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
Remove the copper plate covering the motherboard by desoldering the ten solder points.
