Ga door naar hoofdinhoud
Creative Zen X-Fi LCD Screen Replacement
Wat je nodig hebt
    1. Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: stap 1, afbeelding 1 van 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: stap 1, afbeelding 2 van 3 Creative Zen X-Fi LCD Screen Replacement, Detaching Front Case: stap 1, afbeelding 3 van 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen X-Fi LCD Screen Replacement, Rubber Button Cover: stap 2, afbeelding 1 van 1
      • The black rubber button pad can be removed by simply picking it up.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip Part 1: stap 3, afbeelding 1 van 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen X-Fi LCD Screen Replacement, Button Input Chip: stap 4, afbeelding 1 van 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen X-Fi LCD Screen Replacement, Access Midsection Plate: stap 5, afbeelding 1 van 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen X-Fi LCD Screen Replacement, Unscrew below Button Chip: stap 6, afbeelding 1 van 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Vraag FixBot
      Voeg opmerking toe
    3. Creative Zen X-Fi LCD Screen Replacement, Unscrew below LCD Screen: stap 7, afbeelding 1 van 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: stap 8, afbeelding 1 van 2 Creative Zen X-Fi LCD Screen Replacement, Pull the Motherboard Out: stap 8, afbeelding 2 van 2
      • Lift the right edge of the motherboard off the back case.
      • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: stap 9, afbeelding 1 van 2 Creative Zen X-Fi LCD Screen Replacement, Disconnect the LCD Screen: stap 9, afbeelding 2 van 2
      • Use two fingers to peel back the edge of the ribbon connector that is glued to the bottom of the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen X-Fi LCD Screen Replacement, Unlatch the LCD Screen: stap 10, afbeelding 1 van 1
      • Using a plastic opening tool, unlock the ribbon connector by unlatching the black lever that pins it on the motherboard.
      • Once the black lever arm is open, pull the ribbon connector out to disconnect the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Westley Courchene
3.410 Reputatie
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 71
Altijd: 2,099
