Ga door naar hoofdinhoud
Creative Zen Vision W LCD Screen Replacement
Wat je nodig hebt
    1. Creative Zen Vision W LCD Screen Replacement, Front Cover: stap 1, afbeelding 1 van 2 Creative Zen Vision W LCD Screen Replacement, Front Cover: stap 1, afbeelding 2 van 2
      • Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen Vision W LCD Screen Replacement: stap 2, afbeelding 1 van 3 Creative Zen Vision W LCD Screen Replacement: stap 2, afbeelding 2 van 3 Creative Zen Vision W LCD Screen Replacement: stap 2, afbeelding 3 van 3
      • Run the spudger along the cover and pry.
      • Do this gently to preserve the screen
      • The button pad may fall off when the cover is removed.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen Vision W LCD Screen Replacement, LCD Screen: stap 3, afbeelding 1 van 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: stap 3, afbeelding 2 van 3 Creative Zen Vision W LCD Screen Replacement, LCD Screen: stap 3, afbeelding 3 van 3
      • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
      • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen Vision W LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Put the screen face down so you can see where the ribbon cables are attached.
      • Remove the red sticker that covers the ribbon cable connections.
      Vraag FixBot
      Voeg opmerking toe
    3. Creative Zen Vision W LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
      Vraag FixBot
      Voeg opmerking toe
    4. Creative Zen Vision W LCD Screen Replacement: stap 6, afbeelding 1 van 3 Creative Zen Vision W LCD Screen Replacement: stap 6, afbeelding 2 van 3 Creative Zen Vision W LCD Screen Replacement: stap 6, afbeelding 3 van 3
      • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
      • Remove the screen from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tim Wilson
143 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-2, Regan Spring 2013 Lid van Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Leden
32 handleidingen geschreven
1Gids Commentaar
Where can I get the screen
Home Watch - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 1,835
