Ga door naar hoofdinhoud
Creative Zen Vision W Battery Replacement
Wat je nodig hebt
    1. Creative Zen Vision W Battery Replacement, Battery Removal: stap 1, afbeelding 1 van 3 Creative Zen Vision W Battery Replacement, Battery Removal: stap 1, afbeelding 2 van 3 Creative Zen Vision W Battery Replacement, Battery Removal: stap 1, afbeelding 3 van 3
      • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen Vision W Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Creative Zen Vision W Battery Replacement, Battery: stap 2, afbeelding 2 van 2
      • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
      • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen Vision W Battery Replacement: stap 3, afbeelding 1 van 3 Creative Zen Vision W Battery Replacement: stap 3, afbeelding 2 van 3 Creative Zen Vision W Battery Replacement: stap 3, afbeelding 3 van 3
      • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Follow these instructions in reverse order to reassemble your device.
Tim Wilson
143 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-2, Regan Spring 2013 Lid van Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Leden
32 handleidingen geschreven
3Gids Commentaar
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - Antwoord Deel
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - Antwoord Deel
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 71
Altijd: 7,243
