Ga door naar hoofdinhoud
Creative Zen V Plus Battery Replacement
Wat je nodig hebt
    1. Creative Zen V Plus Battery Replacement, Prerequisite Only: stap 1, afbeelding 1 van 1
      • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
      Vraag FixBot
      Voeg opmerking toe
    2. Creative Zen V Plus Battery Replacement: stap 2, afbeelding 1 van 1
      • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
      • Using a twisting motion, detach the control panel from the device
      Vraag FixBot
      Voeg opmerking toe
    3. Creative Zen V Plus Battery Replacement: stap 3, afbeelding 1 van 1
      • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
      Vraag FixBot
      Voeg opmerking toe
    4. Creative Zen V Plus Battery Replacement: stap 4, afbeelding 1 van 2 Creative Zen V Plus Battery Replacement: stap 4, afbeelding 2 van 2
      • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
      Vraag FixBot
      Voeg opmerking toe
    5. Creative Zen V Plus Battery Replacement: stap 5, afbeelding 1 van 1
      • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
      • Remove the screw located under the display using the 00 Phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Creative Zen V Plus Battery Replacement: stap 6, afbeelding 1 van 3 Creative Zen V Plus Battery Replacement: stap 6, afbeelding 2 van 3 Creative Zen V Plus Battery Replacement: stap 6, afbeelding 3 van 3
      • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
      Vraag FixBot
      Voeg opmerking toe
    1. Creative Zen V Plus Battery Replacement, Battery: stap 7, afbeelding 1 van 1
      • Simply unplug the white colored battery from it's terminal and replace with the new battery.
      • This completes the battery replacement process. Well done!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Brock Schaffer
517 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-5, Baechle Fall 2016 Lid van IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Leden
21 handleidingen geschreven
6Gids Commentaar
This is a good guide as it applies to the Zen V Plus used. My Zen V Plus, however, had a few differences: 1. my Zen’s original battery is soldered to the PCB, there is no plug. So unless the person replacing the battery is experienced at soldering the possibility for damage is very high. This board is very small and it would be very easy to damage this board with a soldering iron; 2. The battery in my unit wasn’t laying loose in the bottom of the unit it was held in with double sided tape. It was a thin, clear double sided tape that looks like ordinary scotch tape. It had a pretty good bond but it was broken fairly easily. Just treat it like everything else in the unit and be as gentle as possible. There is one more thing to be aware of; Pay close attention to the alignment of the slider (for power) to the wiper of the switch it goes to. It can be real annoying to have it all back together and then it won’t turn on.
rchilders11 - Antwoord Deel
Replace battery. Still, saying weak battery. ???? Change cord. Still. Weak battery. ????
bobn_sheraton - Antwoord Deel
WHERE CAN I BUY A REPLACEMENT BATTERY? I’m in South Africa
boland - Antwoord Deel
Replacement batteries can be found on eBay.com. Just search on the number that is on your battery (e.g. creative ba20603r79919 battery). You can also use generic replacements, but make sure that it has similar or higher capacity, and that the dimensions are similar as your current battery.
Peter - Antwoord Deel
What if i use a 500mah battery will it di??
5skimov lolz - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 97
Altijd: 11,462
